IVR to database capture
Discussion in '3CX Phone System - General' started by cjammer, Jul 1, 2007.
  1. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    Is there a way to use the Digital reception to capture information from callers.
    Like have them key in telephone numbers and then I can go back and pull them up with a data reporting tool?
    Is that something that is built in or is it not possible?
    Cjammer
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    atm there is only a call log that you can use for database issues
