Jabra phonesuite supported?
Discussion in '3CX Phone System - General' started by infused, Feb 2, 2014.
  1. infused
    Oct 17, 2013
    19
    http://www.jabra.com/support/jabra-pc-suite
    Thought the link might be old. Currently have Jabra devices configured via usb. They work, however, the buttons on the headsets do not work. Assuming I need this software?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Should be,
    I'm using it with Jabra UC150. The only difference visible is answer/hang-up button working, volume control & mute were working also before installing Jabra Suite.
    However Jabra PC suite is a rather heavy application, using lots of resources.
