Jabra Pro 935 - answer with multifunction button not working
Discussion in '3CX Phone System - General' started by Sean Williams, Feb 15, 2018.
  1. Sean Williams
    Nov 6, 2017
    14
    Hi all,
    As per subject, I cannot get my Jabra Pro 935 to answer a call on my Windows softphone using the multifunction button.
    Instead of answering, it seems to open a new call and sound a dial tone, almost as if it has two channels running simultaenously.
    I have Jabra Direct installed, and updates are current.
    The headset works well in other respects, but this particular feature is not working.
    Any help appreciated.
  2. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    I'm afraid Jabra headsets are not supported by 3CX. Jabra however do have a list of compatibility with 3CX on their own site which you can check.
    As it seems to be a firmware/design issue from the manufacturer please contact their support for more help on this matter.
