Jabra PRO 9400 serien
Discussion in 'Windows' started by NetTel, Aug 26, 2010.
  1. NetTel
    Jul 12, 2007
    5
    Any one that can get Jabra PRO 9400 working with 3CX softphone and the key on headset to hang up call.
    NetTel
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Current released 3CXphone version doesn't support Jabra headset integration - however, the next release is planned to do this.
    Regards
    vali
