Japanese assignment
Discussion in 'CRM / Helpdesk / App Integration' started by pronet4, Aug 28, 2014.
  1. pronet4
    Jul 7, 2014
    Can I assign a variable to the Japanese that you created in the Voice Application designer?
    Currently, the act of assignment of the Japanese variable, variable contents are cleared.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there!
    I'm not sure to understand what you're trying to do. Can you share an example? Some screenshots?
    Thanks.
  3. pronet4
    Jul 7, 2014
    Thank you for an answer
    I'm sorry in strange English
    The contents which confirmed a phenomenon
    Confirm an attached file
      File size:
      179.5 KB
      4,022
  4. VAD_Support
    Aug 6, 2009
    690
    Hi there!
    In the variable assignment component, the screenshot seems to show a pipe character "|" at the end of the variable name. Can you confirm it? In that case you need to remove that character from there.
    Take a look at the following article to understand how to troubleshoot your app:
    http://www.3cx.com/blog/docs/troubleshooting-vad-applications/
    Following that guide you should be able to check the logs and see what's exactly causing the problem.
    Hope the information helps and do not hesitate to contact us again if the problem persists.
    Kind regards.
