Japanese correspondence of name
Discussion in '3CX Phone System - General' started by chikara sugiyama, Jun 15, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hello
    Japanese names are not displayed when you download the recording file, we get the following.
    Example file name:% 83e% 83X% 83g
    Japanese: テスト
    Will it possible to correspond to the Japanese?
  2. Jgrathwohl
    Feb 28, 2014
    24
    You probably need set the unicode in windows to Japanese. This can be found in the control panel under region and language then in the administrative tab. Bottom option for Unicode.
  3. chikara sugiyama
    Jun 15, 2014
    22
    Sorry slower reply.
    I tried to do in various ways, but it did not resolve
    I'll try a little more luck.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Thank you for the feedback I forwarded this to our developers.
