junghanns ISDN cards
Discussion in '3CX Phone System - General' started by shark95763, Mar 2, 2009.
  1. shark95763
    Aug 22, 2007
    22
    Hello all,
    Does anybody know if the Junghanns ISDN cards are supported with 3CX?
    QuadBRI 2.0 PCI or DuoBRI 2.0 for example?
    We are want to change from Asteriks to 3CX if the card works...
    The card supports 4 ISDN lines if i'm not wrong and has the HFC-4S chipset on it.
    Regards,
    Shark
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    The card you have mentioned is not in 3CX list of supported devices , found on https://www.3cx.com/support/
    it is recommended you use one of the supported devices.
    regards
    #2 alexmallia, Mar 2, 2009
  3. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    the only cards that are supported are Sangnoma card's, they have a little piece of software that functions as an sip bridge between 3cx and the card.
