Kaspersky blocks 3cxPhone V12
Discussion in 'Windows' started by thinkagain, May 2, 2014.
  1. thinkagain
    May 2, 2014
    we got the follwoing Problem:
    3cxPhone V12 (latest version) can't connect to 3cx Server when Kaspersky Endpoint Security is enabled (Workstation: KES 10.2.1.23, Win 8.1). We neet to disable KES and start 3cxPhone to get working. If we enable KES again, 3cxPhone keeps working.
    Is there any solutution for this problem? (We gave it to kaspersky support as well).
    Thank you.
  2. thinkagain
    May 2, 2014
    I found a workaround:
    Add in Kaspersky Web-Antivirus the IP-Address of you 3cx Server to the "Trusted" like *IP_OF_YOUR_SERVER* and 3cxPhone will work.
  3. roland.s
    3CX Support
    Mar 28, 2014
    75
    5
    hello Thinkagain,
    Please refer to the link below regarding antivirus configurations and 3CX. You may scroll down for instruction specifically on Kaspersky.
    Hope this helps.
    http://www.3cx.com/blog/docs/3cxphone-presence-self-help/
  4. Omid Moridi
    Jun 8, 2014
    In setting tab, Antivirus protection, Web Anti-virus click on settings then add *your server ip* with * sign like *192.168.1.2*.
    and allow run 3cxphone in trust applications.
