KB4041693 Server 2012 R2 - Issues with 3CX Client Connection and remote console access
Discussion in '3CX Phone System - General' started by EduTech, Oct 21, 2017.
  1. EduTech
    Sep 21, 2017
    After the sever rebooted to completed the install, we had issues with the all remote client apps connecting to the web api and accessing the console from outside the LAN would cause a timeout.
    Tried a reinstall of the PBX but still the same though a slight improvement.
    Uninstalling KB4041693 resolved the issues immediately.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Haven't had any other reports about this yet, but we can try to replicate. What version of 3CX is this happening on? V15.5 or V14? If it's V14, are you using IIS as the web server?
  3. EduTech
    Sep 21, 2017
    False alarm sorry. The issue began happening again shortly after posting this.
  4. NickD_3CX
    Jun 2, 2014
    1,255
    63
    In that case, the usual suspect is AntiVirus software on the 3CX Server or DPI on the firewall.
