keep getting disconnected during calls randomly
Discussion in '3CX Phone System - General' started by C51, Sep 3, 2007.
  1. C51
    C51
    Aug 10, 2007
    18
    10:16:46.421 StratLink::eek:nHangUp [CM104001] Call(109): Ln:10000@C51043021 hung up call; cause: BYE; from IP:192.168.43.21
    10:16:34.531 CallLegImpl::eek:nConnected [CM103001] Call(109): Created audio channel for Ln:10000@C51043021 (192.168.43.21:12534) with third party (192.168.43.204:33000)
    10:16:34.515 StratInOut::eek:nConnected [CM104005] Call(109): Setup completed for call from Ext.204 to Ln:10000@C51043021
    10:16:34.515 CallLegImpl::eek:nConnected [CM103001] Call(109): Created audio channel for Ext.204 (192.168.43.204:33000) with third party (192.168.43.21:12534)
    10:16:32.515 CallConf::eek:nProvisional [CM103003] Call(109): Ln:10000@C51043021 is ringing
    10:16:32.312 CallConf::eek:nIncoming [CM103002] Call(109): Incoming call from 204 (Ext.204) to sip:008451224777@192.168.43.101:5060
    ^ there is the log, unsure why it only happens on certain numbers
    any help would be welcomed
    thanks
    Jordan
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Can you please test calls of same length and verify that this is not happening when you exceed a specific lenght of call for all calls?
    btw what is C51043021 is it a gateway? if yes, which model/brand?
    Regards...
  3. C51
    C51
    Aug 10, 2007
    18
    testing complete
    it varys at how long before it cuts off sometimes it doesnt cut off,
    also yes that is the gateway
  4. Costas3CX
    Jan 23, 2007
    217
    sir which model/brand is giving you these problems
  5. C51
    C51
    Aug 10, 2007
    18
    model/brand of what
    its the 3cx server, its on 2 linksys spa3102's for each of the 2 lines,
    any ideas?
  6. C51
    C51
    Aug 10, 2007
    18
    have look at this, all seems to be ok, i can make and recieve calls, they just sometimes cut out for no real reason
    someone said somthing about the disconnect tone
    but i cant even find this on the SPA config
    Jordan
