Keep the main screen on the 3CX?
Discussion in 'Windows' started by mikesmithrs, May 25, 2011.
  1. mikesmithrs
    May 25, 2011
    Is there a way to keep the main screen when using the 3CX? When it 'flips' you can't see all the lines that are ringing anymore.
  2. mikesmithrs
    May 25, 2011
    If I have all five lines ringing, answer line 1, then move to line 2, if Line 1 rings again, the phone will 'flip' to the answer screen and not let me answer the other lines until I answer the latest call, so lines 3,4 & 5 are left ringing.
  3. antler
    May 8, 2011
    40
    Hallo forum,
    I guess no-one has a solution to this?
    Gruß
    Antler.
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    This the current behavior and cannot be changed by user. Also, there is no discussions nor plans to chage this in the future.
  5. mikesmithrs
    May 25, 2011
    It makes no sense for the phone to do this - why would you not want to answer calls in the order they come in?
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    I don't get your point here: make three calls to the 3CXPhone - the answering screen will display three items, one for each call, the most recent one on top. Each item contains caller's phone and ID/contact, alongside with the operation you want to perform, so you may select the one you want. Once you answer it, display is switching to the main display, with the line buttons blinking for remaining incoming calls.
  7. mikesmithrs
    May 25, 2011
    But it doesn't work that way. We have 5 lines by the way.
    5 calls come in. Line 1 is answered. Then you move to line 2. While talking to line 2, another call comes in on line 1. The screen "flips" from the phone with keypad screen to the answer screen showing only line 1. You have to answer it before it goes back to the phone screen, leaving the calls on 3, 4 and 5 waiting. Then while you are talking on line 1, line 2 rings and flips it again - still leaving 3,4 and 5 unanswerable.
