Kerio Winroute Firewall RTP Problem
Discussion in '3CX Phone System - General' started by menace8000, Jan 9, 2011.
  1. menace8000
    Apr 16, 2009
    Hi Guys,
    I have been playing with 3CX for some time now, had some issues with the firewall and getting the correct ports opened, so moved the VOIP server to outside my Kerio Winroute Firewall.
    Subsequently, I got nailed by some hacker who managed to upload 6GB in an afternoon and crash my service for the rest of the month, so I have decided to try get my port forwarding correct.
    I currently have the following rules in place
    Source - LAN -> Destination - WAN
    TCP/UDP 5060 - NAT - SIP
    TCP/UDP 5090 - NAT - Tunnel
    TCP 3478 - NAT - STUN
    UDP 9000-9015 - RTP
    The Server logs on to all VOIP providers with no problem, Phones all online, but when I make a call I get no audio, in my filter I see the following report
    DROP "Def rule" packet from LAN, proto:UDP, len:200, ip/port:192.168.8.49:9014 -> 202.85.241.126:17898, udplen:172
    DROP "Def rule" packet from WAN, proto:UDP, len:200, ip/port:202.85.241.126:17898 -> 192.168.123.124:9014, udplen:172
    From what I understand, 9014 is the RTP port, why is this being translated to 17898 from LAN and back again, if I open this 17898 port audio starts to work, but each time this port is different??
    Can anyone help me here, all phones are down till I can sort this,
    Cheers
    Dennis :oops:
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Please update your rules to reflect UDP 9000-9050 or as indicated withing your 3CX settings. We will need some logs and/or wireshark capture.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    I think that you should look in your Kerio Winroute Firewall settings, because some defence rule in the firewall blocks UDP traffic to and from the WAN.
    I don’t know if you can disable e.g. the DoS Defence, because this setting(s) can block a lot of different traffic through your router, and then start from here till the problem is back again.
  4. menace8000
    Apr 16, 2009
    Thanks Guys,
    What I havedone to make it work so far is to open RTP ports 16384 - 25000, this seems to work, but in my opinion are a lot of open ports??
    What I am trying to work out is that even though in 3CX i have set it up to use RTP on ports 163834 - 16410, in the initial kerio log, the port seems to get changed to another port on the other side??
    DROP "Def rule" packet from LAN, proto:UDP, len:200, ip/port:192.168.8.49:16384 -> 202.85.241.126:17898, udplen:172
    DROP "Def rule" packet from WAN, proto:UDP, len:200, ip/port:202.85.241.126:17898 -> 192.168.123.124:16384, udplen:172
    I am not sure if it is the kerio firewall that is making this change or 3CX, but if I do not have both ports open in the firewall, I have to RTP audio. I have tracked these ports, and they range from about 16500 to 25000 so far, so hence having to open so many ports in the firewall outbound rule.
    I have the 3CX software on a PC, this is in the LAN behind the Firewall dual NIC PC, then they go through a modem, so there is NAT in the modem as well, I have put the Firewall PC in the DNZ to avoid having to open more ports again??
    Thanks for your help here, it has been driving me crazy!!!! :cry:
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    IP1:port1(PBX Host)<->IP2:port2(NAT translation)<->...internet...<->IP3:port3(remote party)
    192.168.8.49:16384 is IP1:port1(PBX Host)
    What is 202.85.241.126:17898? Is it"IP2:port2(NAT translation)"? Is it "IP3:port3(remote party)"?
  6. menace8000
    Apr 16, 2009
    Hi Sy,
    IP Port 1 - 192.168.8.49 - VOIP Server (PBX Host)
    IP Port 2 - 192.168.8.254 Inside / 192.168.123.124 outside the Firewall (NAT)
    IP Port 3 - 202.85.241.126 - Remote party
    Does this make sense??
    Dennis
  7. complex1
    Jan 25, 2010
    832
    52
    Somewhat.
    As I understand, after searching the internet, is the Kerio Winroute Firewall a software application running on a dedicated computer. (this explains IP Port 2)
    If so, is it possible for you to use a router instead the Kerio? Maybe this may resolve your problem.
