Key and Lamp functionality
Discussion in '3CX Phone System - General' started by suburban74, May 23, 2007.
  1. suburban74
    May 23, 2007
    7
    hi
    can you tell me if your pbx supports key and lamp.. ie : can i share a call appearance for a line or ext on multiple phones and have the status led change if the line or ext is off hook / busy / on hold?
    i will use either linksys spa962 or snom 360 phones (currently testing).
    i am looking to replace an old key and lamp and want to have hybrid functioinality.
    thanks
    simon
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    This can be done using the Windows Call Assistant, it will show line status, extension status and so on....
  3. suburban74
    May 23, 2007
    7
    so does that mean you can't do it on the phone itself using the key LED's.. only the windows web browser console?
  4. TwigsUSAN
    Jan 31, 2007
    45
    That is correct. Currently it is not a feature that is available.
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Not completely true. You can set up Snom 360 to flash programmable lamp to flash on incoming calls from or to corresponding SIP address. It doesn't require any additional functionality of 3CX PBX.
  6. TwigsUSAN
    Jan 31, 2007
    45
    My mistake. I wasn't aware that particular phone could.
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    I've checked Snom 360 myself. Probably, linksys can do something like this also.
  8. suburban74
    May 23, 2007
    7
    GREAT. i have a snom and a linksys, as i am testing both handsets.. can you tell me how you did this - and i can see if i can replicate it on the linksys.
  9. suburban74
    May 23, 2007
    7
    hi..
    can someone tell me how this was implemented on the SNOM so I can try and replicate it?
    Thanks!
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    It is clearly described in Snom manual. Page 41 of snom 360 manual, section 'Programmable keys'
  11. marcovalli
    Feb 26, 2007
    14
    GRANDSTREAM GXP2000
    I have the some problem with using grandstream GXP2000. Can somebody help me ??
  12. suburban74
    May 23, 2007
    7
    hi
    sorry but the manual is not very clear at all. i don't understand what the string is i need to put to make it subscribe to the other extension state or what option to select from the drop down, ie: line/shared line/extension
    can you offer any more advice?
    thanks
    simon
  13. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    I think there was a misunderstanding here. Admin didn't say web browser console. Admin said Call assistant. Call assistant is a small client software that we offer for free with the 3CX Phone system. You can download it from the login page by just clicking on "Get 3CX CallAssistant" . It will display call history info on a per user basis since it is configured on a per user basis. It will display line and extension availability. Also que membership. Furthermore it gives you the chance to login to ques and transfer call to voicemail if you wish to ignore the call while it is ringing and more.
  14. benzinbruder77
    Sep 19, 2007
    I have tried all settings on our snom360, but i don't work.
    can someone tell me the exact setting of the "programmable key" for the busy lamp funcionality.
    thanks
  15. Nick Galea
    Jun 6, 2006
    2,005
    308
    If you are referring to BLF i.e. busy lamp field, we do not yet support it. Its on the road map, probably end of year we will have it. Until then please use call assitant...
