Keyboard or Laptop Volumne Control turns off sound
Discussion in 'Windows' started by shanonl, Apr 8, 2013.
  1. shanonl
    Feb 27, 2013
    Using the USB keyboard or laptop volume control buttons mutes the 3CX voip phone without indication (unlike when you click the mute button). This happens either whilst dialing, ringing or talking. To workaround I must cancel the call, adjust volume on task bar, and redial.
    3CX Phone ver 6.0.26523.0
    Windows 7 64 bit Enterprise 6.1.7600
    Dell Precision Laptop 4500, Intel i7 2.5Ghz, 4GB RAM
    and also
    Windows 7 64 bit Professional
    HP Elitebook 8650W, Intel i7 2.8GHz, 8GB RAM
    Shanon
