Keypad not sending tones in call (can't log in to voicemail)
Discussion in 'Android' started by lifeisfun, Jan 21, 2011.
  1. lifeisfun
    Oct 18, 2010
    6
    Tested on 3 android devices and they all have the same problem
    If you want to type in your password to log in to voice mail account
    the keypad pushes are not received.
    Works fine using other SIP software for android.
    It would be nice if this can be fixed in next version.
    10,842
    299
    Re: Keypad not sending tones in call (can't log in to voicem
    Have you tried changing the DTMF Method? Menu key/Profiles/select your profile/Advanced/DTMF Method. There are three choices to "play with" , see if one of the other works for you.
    Tim Apger likes this.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    I'd suggest you follow Leejor's advice on this and try again.
  4. lifeisfun
    Oct 18, 2010
    6
    Thanks for reply guys, will try that.
    UPDATE:
    That did it, changing to Sip-info fixed that problem :)
    Thanks again!
