Konftel 300Wx DECT Conference phone
Discussion in '3CX Phone System - General' started by flaming, Jan 23, 2014.
  1. flaming
    Dec 3, 2009
    7
    I am looking at getting one of these for our 3CX system.
    Anyone configured with and have any advise / guidance or feedback ?
    Many thanks
    Sab
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    We have a lot of Konftel's out there.
    This model connects via analog rj11 jack.
    So you would need an ATA to make it work.
    I dont know how it would work if you try via usb.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    I assume that you selected the W version to avoid cables. They work well when used in conjunction with a FXS gateway but you will never be able to take advantage of g722 (HD Audio). We use mostly the IP version, and yes there are cables (or cable if you use PoE).
  4. Aputsiaq
    Nov 29, 2016
    I'm currently having problems with a Konftel 300WX, where i can't get 3-way conference to work.
    I tried "Instant" conference, and when i call the 1st number and press OK to call the next participant, i get stuck with the first participant.
    Any solutions for that or anyone experienced the same?
