LAN client disconnecting
Discussion in 'Windows' started by igormillo, Apr 3, 2008.
  1. igormillo
    Apr 3, 2008
    I have just installaed 1 server e 2 client version 4393, all over Win XP and simply in a LAN. One of the clients disconnect every few minutes and I have to exit the program to riconnect.
    On the server I have this message:
    [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.20:5060 tid=ba60142bc2448a2e cseq=REGISTER contact=13@192.168.1.47:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    On the same PC then I installed "Express Talk" with which everyting works fine.
    Thank you for your work.
    Igor Millo
    Trieste
    ITALY
  2. darrellchapman
    Nov 26, 2007
    268
    How did you setup the 3CX client? Using 3CX integrated authentication or SIP authentication?
