LAN SETUP spa-3102
Discussion in '3CX Phone System - General' started by spec, Aug 15, 2008.
  1. spec
    Sep 8, 2006
    51
    Here’s the ip I’m using
    netgear router 192.168.0.1
    pc with 3cx 192.168.02
    spa-3102 192.168.0.3
    on the spa-3102 wan setup internet connection settings type = DHCP
    and optional setting primary DNS 192.168.0.1 DNS manual (using this as I’m trying to get the time going.
    On LAN SETUP
    Lan network setting lan ip 192.168.0.3 is that correct or should I point to netgear or 3cx
    Oh and enable DHCP server set to NO
    Does that all sound correct
  2. ess
    ess New Member
    Jun 8, 2007
    133
    Wan Setup:
    Connection Type: Static IP
    Static IP: 192.168.0.3
    Gateway: 192.168.0.1
    Netmask: Your subnet
    Primary DNS: 192.168.0.1
    Enable WAN Webserver: YES! (important)
    LAN Setup:
    Enable DHCP Server: No
    (Optional) Networking Service: Bridge (so you can connect something to the lan)
    Physical Setup: Plug the SPA3102 into the router using the INTERNET PORT. Not the ethernet port. Optional: Plug a lan device into the Ethernet port.
    Follow the rest of the 3cx guide.
    Let us know how it goes!
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    I would not have your router as a DNS server, use the DNS server of your ISP.
    I have my WAN IP as the IP of the SPA, I do not use the LAN setup.
    3CX points to the WAN port eg 192.168.0.3
  4. spec
    Sep 8, 2006
    51
    Great got most of it going now thanks have some problems with outgoing pstn calls
    But that shouldn’t go under the heading of lan setup so I’m going to start a new thread.
    Thanks again for the help and maybe you could help with my pstn
