LAN to LAN redudancy
Discussion in '3CX Phone System - General' started by xserius, Mar 21, 2018.
  1. xserius
    Oct 11, 2016
    10
    Hi!
    I've been busy looking into the redudancy of 3CX and want to implement this.
    Now i have a question about it and hope someone here has the answer.
    I want to use 2 LAN servers and make them redudant with 3CX, now there is a manual about this on the site but i believe that scenario only is for 2 systems on 2 different sites through the 3cx FQDN.
    Has anyone experience with LAN to LAN redudant software and what are the things i need to take notes of?
    Can i use the 3CX FQDN for this even when 2 servers are under the same public IP and LAN ? i assume not.
    If not does someone have a example how to do this in a LAN to LAN scenarion.
    Hope to hear, thanks!
