Lancom 1724 & 3CX
Discussion in '3CX Phone System - General' started by xxxomxxx, Dec 8, 2007.
  1. xxxomxxx
    Oct 5, 2007
    11
    Hi all
    i am trying to set up a Lancom 1724 with newest LCOS Bios and 3CX.
    Well, i cant use the Lancom as "Gateway" and i dont know why, so after 3hours of trying all possible connection settings, i decided to use VoIP Users to connect to the Lancom instead. It is a bit cumbersome, but it works. (you need one line per ISDN MSN/VoIP Number and you need to set up group calling on the lancom etc.)
    The first problem: if the lancom resets itself or i change the config of the lancom, the line isn't registered anymore - and it does not re-register itself automatically. Selecting the line and registering it manualy solves the problem...
    the second problem, which i think is not related to the 3cx, is that i enabled group calling on the Lancom, but the phones registered on the 3cx wont ring. If i set it up in the way that the number receiving the call is only the one on the 3cx, it works.
    any help..also instructions to use the lancom as a Gateway... would be highly apreciated..
