Language as a variable
Discussion in 'CRM / Helpdesk / App Integration' started by Louis-Philippe, Sep 18, 2012.
  1. Louis-Philippe
    Sep 7, 2012
    5
    I'm trying to dynamically change the language for text to speech in a user input component. Correct me if I'm wrong, but it doesn't seem to be possible to set text to speech voices as a variable or as an expression. I try to use the usual syntax, like callflow$.Voice, but it doesn't works. Is their a technical reason?
    Thanks for the help and have a nice day,
    Louis-Philippe
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You're right, currently it is not possible to set the TTS voice using an expression. To do it you would have to use a Conditional component to select the language, and add a different Prompt Playback component into each branch. You could create a custom component to do this, that way you don't need to add the conditional component everywhere.
    I think it's a good idea to be able to set it using expressions, in case you need a multilanguage IVR. We'll consider it for the next version.
    Regards,
  3. Louis-Philippe
    Sep 7, 2012
    5
    The problem with using a Conditional component to select the language is if the user doesn't input values before the timeout of a user input control, the TTS won't play again.
  4. VAD_Support
    Aug 6, 2009
    690
    When you need to collect user input, you have to put a User Input component into each branch of the Conditional component, and configure the prompts with a different voice in each case.
  5. Wilgner Garcia
    Feb 17, 2014
    Hello Louis,
    i am trying to execute the text speech with another voice/language (different from pattern, Microsoft Anna).
    I installed 2 another voices on Microsoft Text to Speech, these voices are appearing on windows, and if i select one of them on control painel, and not set the voice name on VAD, the voice that "3CX execute" continues being Microsoft Anna.
    I tried to use the names 'MIcrosoft Heloisa', 'Heloisa', and others variations on the field Voice Name, but without success.
    How do you set a voice in that field? Are you using which languages?
    Wilgner
  6. VAD_Support
    Aug 6, 2009
    690
    Hi Wilgner,
    Keep in mind that some voices are only available for 32 bits, and in that case if your server is x64, the VAD application will not see the new voices. Check that in first place.
    Regards.
