Language not loaded provisioning Cisco SPA512G by 3CX v12
Discussion in '3CX Phone System - General' started by cactus, Nov 17, 2014.
  1. cactus
    Oct 17, 2014
    7
    I can provision the phone - all values are set except language and localizing.
    I followed this guide:
    http://www.3cx.com/blog/ip-phone-configuration/cisco-display-language/
    Firmware is the newest 7.5.6a and I've also tested with 7.5.5.
    Language has been set to Danish at the extension page.
    Language file is from SPA30x_SPA50x_SPA51x_SPA525G_7.5.6_Dicts.zip:
    spa50x_30x_dk_v756.xml
    and copied to:
    C:\ProgramData\3CX\Data\Http\Interface\provisioning\XXXXXXXXXX\firmware\cisco
    The log indicates no error.
    What am I missing?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Re: Language not loaded provisioning Cisco SPA512G by 3CX v1
    Hi there,
    Please perform firmware upgrade (downgrade in your case) from 3CX console / Phones page, you will be prompted with firmware 7.5.5 which is the latest supported by 3CX. Note that this will also upload automatically the language pack along with firmware, so you don't need to do anything with zip files manually.
    Then, just switch language from the extension / phone provisioning tab.
    Reprovision extension, restart phone.
    Let me know if this solved your issue.
  3. cactus
    Oct 17, 2014
    7
    Thanks for getting back this quick.
    However, the Upgrade Firmware option is greyed out. Both with 7.5.5 or 7.5.6a firmware on the phone.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    This option is available only if you have a valid maintenance contract, and if your extension is provisionned.
  5. cactus
    Oct 17, 2014
    7
    I'm running the SAOY-3LMW-U3OT-GLJV trial license.
    Shouldn't it provide the option to check out provisioning?
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Then it's normal, with demo key you don't have a maintenance contract, so you can't do firmware upgrade, service pack upgrade, etc..
  7. cactus
    Oct 17, 2014
    7
    Oh, that explains. Too bad.
