Latest Debian 3CX ISO
Discussion in '3CX Phone System - General' started by alexko, Jul 24, 2017.
  1. alexko
    Jul 14, 2017
    15
    I am searching for the latest iso release, the one that is on the site with 8.6.0 is pretty old.
    Is there a version with Debian 8.8.0?
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    932
    150
    Pretty old compared to? Linux is good about security patches so 'old' versions really aren't a problem unless you need to use cutting edge hardware. That being said, they are working on certifying the latest Debian release: https://www.3cx.com/blog/docs/linux-version-9-stretch/
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    Hi alexko,
    No problem.
    The installation of v8.6.0 ends with a update to the latest available version 8.8.x
    It is also possible to do a manually update to the latest version by entering next command:
    “apt-get update && apt-get upgrade”
    Hope this will help.
  4. alexko
    Jul 14, 2017
    15
    Yep I was talking about Debian 9.1. The iso that is released is based on Debian 8.6.0 and it is the same iso as the one that was given out during the beta phase back in October.
    Complex thanks for the info, I didn't know that. Well to rephrase my question when the iso will be updated to latest debian 9.1?
