LD calls ring, then busy tone and drop?
Discussion in '3CX Phone System - General' started by scythe000, Jun 4, 2012.
  1. scythe000
    Nov 8, 2011
    66
    This is odd:
    Code:
    13:12:26.608  [CM503020]: Normal call termination. Reason: Not found
    13:12:26.608  [CM503016]: Call(3097): Attempt to reach <sip:2062095254@172.16.252.5;user=phone> failed. Reason: Not Found
    13:12:26.592  [CM503003]: Call(3097): Call to sip:12062095254@172.16.252.250:5060 has failed; Cause: 404 Not Found; from IP:172.16.252.250:5060
    Has anyone seen this?
    10,573
    247
    This is going to a gateway trunk? If so, what type? Does the gateways show as registered? Does this happen with all LD calls, local calls? Is this a new installation/ Did this problem just start, or has it never worked?
