LDAP/Active Directory Authentication
Discussion in 'Ideas' started by James Gauci, Jul 4, 2017.
LDAP/Active Directory Authentication 4.9 5 39votes
4.9/5, 39 votes
  1. James Gauci
    Jul 4, 2017
    5
    Hi All,
    I am a prospective customer of 3CX for a team of 200 clients across a WAN, however one area that is essential for us is LDAP/Active directory authentication of users.
    While I see that LDAP integration is available for the web meeting system, the contact component of 3CX has is own seperate credentials database.
    Passwords can be revealed in clear text which I agree is a handy feature for some but a security concern in our environment.
    Furthermore, it means we need to manage two seperate directory username/password systems which is time consuming.
    Other competitive solutions have this functionality by default, however if this issue was resolved for us, we would jump onto 3CX tomorrow.
  2. James Gauci
    Jul 4, 2017
    5
    Furthermore to my last post, as the integration is trivial to include (Since there are many open source modules availbile), I could easily develop a module to do this if the resources in 3CX are available? (3CX admins feel free to clarify). Regards
    HH60 likes this.
  3. HH60
    Nov 29, 2016
    15
    5
  4. SupportRequestor
    Mar 23, 2016
    29
    8
    On the note of security concerns over password reveals, the account used for LDAP queries has its password in the clear in the parameters section.
  5. BayMitch
    Sep 3, 2013
    12
    5
    LDAP integration is also importend in perspective of security.
    for us +1
  6. Network Emad
    Oct 27, 2017
    32
    dear are there any software make synchronization between 3CX Pro and Active Directory. i dont want to use the import AD option. i think there are different way to make this integration between AD User and 3CX users list active. if i disabled any user in active directory it will be disabled in 3cx and the client will not be able to use his IP Phone because this user is disabled in Active directory.
    Phillip Horn and craigreilly like this.
  7. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
  8. mtech1
    Jan 25, 2010
    26
    5
  9. RogerS
    Dec 12, 2017
    13
    7
    This Active Directory integration is necessary for phone provisioning, but also SAML authentication. The availability of this integration would be great step ahead for the 3CX solution.
  10. Silly English Kniggit
    Sep 13, 2017
    215
    76
    I agree that this would ease the issues around adoption of the webclient.
    techclarity likes this.
  11. PaulusAgung
    Feb 16, 2018
  12. techclarity
    Nov 14, 2014
    90
    36
    Exactly. We have not really pushed the web client to our clients because we do not want to have to deal with another password that users will forget.
  13. DocTechAZ
    Nov 17, 2017
    46
    12
    I dont expect this will be seen any time soon, as to integrate this with the complex account structure 3cx uses currently would be a much larger hassle than i think you may realize. There are opensource implementations of LDAP yes, however those still would need to be further adapted to bridge the gap.
    Were not talking about linking LDAP accounts with unix/linux accounts which is trivial in most distros, were talking about a proprietary account system which 3cx uses.
    If anything, a sync tool might be simpler. But i definitely wont be holding my breath for it.
  14. Jason Spruill-Jenkins
    May 8, 2017
    you could use LDAP for just authentication and to read from which should be pretty simple to configure and setup.
    If you use the workflow of User in LDAP, Provision Phone, User logins. you can achieve this by a basic ldap query in the UI, when you make an extension, make a "Select user from LDAP" button, which will pull attributes like name, e-mail, ect. you give them an extension and it shoots off the e-mail. allowing the user to then login to the webUI with the samaccountname and it will check the password against ldap and give a pass/fail.
    if you wanted to take it a few steps farther, you could have it read from AD for disabled accounts in like a cron job or windows scheduled task, you could also check to see if the account still exits at all as well.
    if you took this approach, adding two items to the current user table should be all that is needed. 1. samaccountname / login, 2. a Boolean field to denote that extension to use ldap auth
    if you wanted to get all crazy with it, you could add in write back ability with a mapping feature, like with the SIP header mappings. where the DID can write back to Office Phone, the extension could write back to a field as well on creation or update.
    Phillip Horn likes this.
  15. Jean-Francois Godbout
    Jul 5, 2017
    5
  16. palmaz
    Aug 22, 2017
    17
    We are prospective client of 150 users, and this is a big issue for us too. AD authentication would be excellent. Many competitor pabx's already have this.
  17. Phillip Horn
    Sep 1, 2017
    9
    Active Directory integration or Office365 integration would be phenomenal! I'm still searching for a basic script that I could use to add or change extensions based on AD accounts, but I haven't been successful. We're cautious about deploying the webclient in our environment as well, because we can't even get our helpdesk guys to remember their password - I'd hate to try it with hundreds of users.
    At the very least, a password sync from AD to 3CX web client for extension matches in AD would go a long way. We create users in an ERP system and then a script creates the AD account. If we could add 3CX accounts to the script and then sync the passwords, wow. Better still an automatic sync from 3CX to AD.. Or use LDAP to look authenticate rather than a 'local' password..
  18. Figment
    Apr 5, 2018
  19. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,956
    179
    unless you are clearing cache each night on the web browser... the webclient remembers the login.
  20. sentrianjames
    Feb 19, 2018
    15
