LDAP Import
Discussion in '3CX Phone System - General' started by assad-sit37, May 14, 2013.
  1. assad-sit37
    Aug 6, 2012
    12
    does some knows how to use LDAP Import feature when local domain doesn't have extension.
    Our network domain is called RESAUCORP but 3CX need something like RESEAUCORP.lan, .local, or other?
    thanks.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    Single-label DNS Names are not recommended... and not easy to rectify.
    http://support.microsoft.com/?id=300684
  3. assad-sit37
    Aug 6, 2012
    12
    Craig,
    Thanks for link, and I fully agree with you.
    So it was also a problem in older AD deployement that allow this (we are under 2003). and this will be corrected into or future migration. By exemple we have discover that WS2012 doesn't not accept the folowing TLD = .lan.
  4. craigreilly
    Feb 1, 2012
    3,545
    298
    I wish there was better news for you.
