Lenovo K5 Android 5.1.1
Discussion in 'Android' started by daktur, Apr 4, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    Hi All!
    I am trying to provision an extension on a Lenovo K5 running Android 5.1.1 and the provisioning filetype is not recognized by the phone as 3cx file to configure the application.
    Any ideas?
    Thanks a lot!
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    Download the config first and then click to import
    Thank you
  3. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    Where do i have the option to import?
  4. Marios Neophytou
    Mar 1, 2016
    258
    12
    1. Resend the Welcome email on your email address and then click to download it (look screenshot).
    2. Go to the top notification area on your android phone and you will see the 3cxconfig and click on it
    Hope this helps
  5. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    That's what he did, but the file is not associated with 3cx.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,399
    455
    In that case you will need to use a file explorer software on your android device. Personally i use an app called explorer. Open the app and then navigate to your downloads and find the welcome email. Select and choose open with. Choose 3CX client
  7. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    At the end he Is, unfortunately, usung GS wave.
    Thanks all.
