Let's Encrypt - Streamlined?
Discussion in '3CX Phone System - General' started by Bob Denny, Nov 15, 2017.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    I read 3CX in Cooperation with Certificate Authority Let’s Encrypt, in which it says
    I have combed the Version 15.5 Administration Manual (which can't be searched :-(( ) and can't find anything on this. I did click on the "For more information click here" in the admin UI Security Settings, Secure SIP tab, and got to How to Configure Secure SIP – TLS but that shows how to use SimpleCA to create a bogus cert. I am interested in using Let's Encrypt. Where is the "streamlined process" info? Did I miss it during the PBX Express process maybe? Is it available after the fact (I used PBX Express on Google Cloud). I am a 3CX Professional licensee.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    736
    113
    Unfortunately the LE integration is strictly for the web interface. It has nothing to do with SIP-TLS although it certainly should have with the original marketing language touting 3CX as the 'most secure'. I'm hoping the LE integration will be extended to support SIP-TLS
  3. StefanW
    Jun 2, 2009
    1,199
    79
    let me ensure you that we are on it to re-use it for TLS also... but there us much work attached to it. So dont expect this tomorrow...
    cobaltit likes this.
  4. Bob Denny
    Feb 21, 2009
    131
    Ah, OK. Sorry for the misunderstanding. I definitely understand the work involved. At present, it appears that 3CX requires a cert with the common name set to the "inside" IP address of the switch. No CA will issue certs for an IP address.
  5. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    https://www.3cx.com/docs/secure-sip/#h.a85adzue8m6w
    I also wonder how we can import certificate in Windows client when there is no such button?:confused:
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Sp3 will have it inbuilt.
    If you want pm me and I give you a test build. You will install and find out that when you setup 3CX, the lets encrypt certs will be used for TLS..
    poynter.net likes this.
  7. cobaltit
    Mar 22, 2012
    736
    113
    This is welcome news!
