LG Opticon integration - technical spec missing
Discussion in '3CX Phone System - General' started by qz, Oct 30, 2009.
  1. qz
    qz
    May 12, 2009
    10
    Has anyone tried integrating with an LG Opticon system? I can't seem to find any technical specifications to find out how I would do it. It offers VOIP, but I dunno if it's SIP or not.
    Dave
    10,360
    226
    By "integrating", what do you mean? Trunking between the two? You should be able to do that given the right adapters, it might be a bit awkward. If you mean , can you use the LG sets on 3CX...then no, I would suspect that it is a proprietary system.
    Reading the descriptions on the net doesn't mention SIP at all, and if it were using SIP, it would be a big selling point and the would mention it.
