LG Optimus V freeze with recent Android update
Discussion in 'Android' started by bbrannon, Jul 16, 2012.
  1. bbrannon
    May 31, 2012
    3cx android has worked perfectly until the last two updates. Now it freezes and requires battery removal to restart phone. Noticed several others with same problem, other devices, in the Play Store comments. Any possibility of getting the May 2.0.0 apk.
    Device Info
    Phone Model: LG Optimus VM760
    Firmware Version: 2.2.1
    Issue Info
    Handset: N/A
    Contacts: N/A
    Connection: WiFi
    Server: External chicago.voip.ms
