LG P930 - speaker/earpiece selection issue
Discussion in 'Android' started by csturgeon, May 24, 2012.
  1. csturgeon
    May 24, 2012
    Device Info
    Phone Model: LG-P930
    Firmware Version: 2.3.5
    Kernel: 2.6.35.11
    Build: GRJ90
    SW ver : LG-P930-V10j-FEB-26-2012
    3CX ver : 1.3.4
    Issue Info
    Handset: When making a call, phone defaults to speaker even though it says earpiece, resulting in static and echo until earpiece is selected manually. Has this been seen with this phone? Is there a fix?
