Licence on upgrade/restore
Discussion in '3CX Phone System - General' started by cfive, Oct 16, 2009.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    After a version upgrade and restore, or after a restore only, is the license also restored? Or, does the license information always need to be re-entered and activated?
    Is there some place in the console that the license detail/status is displayed?
    Thanks - Les.
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Sorry, I see the license key is displayed on the Activate License page of the console. I presume this means it's been restored and doesn't need to be re-activated?
    Thanks - Les.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Correct, at least with v8 this seems to work perfectly, I have tested that repeatedly.
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Thanks, Kerry.
