License: 60 error
Discussion in 'Windows' started by jappe@vellance.com, Nov 6, 2015.
  1. jappe@vellance.com
    Nov 6, 2015
    When trying to active my license I get an unexpected error license key activation failed license: 60 system 0
    I've searched everywhere but can't find a reference or solution for this.
    We are running V12.0.3xxxxxxx
    Can anybody help?
    kind regards
    jappe reuling
  2. Chris_3CX
    Chris_3CX Guest
    Please refer to http://www.3cx.com/blog/news/license-error/
  3. jappe@vellance.com
    Nov 6, 2015
    thanks! Couldn't find that via the interwebs. Should work out, blog is pretty clear.
