License acticvation error on a new computer
Discussion in '3CX Phone System - General' started by SafdarHaider, Aug 10, 2012.
  1. SafdarHaider
    Aug 10, 2012
    Hey guys,
    We need to retire the computer that we installed 3CX system on originally. So, we installed a parallel copy on a new computer to make sure it works before taking the existing computer offline. When we try to activate the license key on the new computer, we get the following error...
    license.unexperrLicense Key Activation Failed License: 61 System:0
    We are running 3CX system version 10.0.22686.2297.
    Please note that our "upgrade insurance" has expired. Does that have anything to do with it?
    We don't want to upgrade, just reinstall the same version on a different computer.
    Any help is greatly appreciated.
    Regards,
    Safdar
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,534
    298
    I would contact the person you bought the license from. 3cx might have to clear your Mac Address from their license cache.
  3. SafdarHaider
    Aug 10, 2012
    Thanks for your response. I will contact the person/company we purchased the 3CX system from.
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    please apply Service Pack 6 from the main 3CX Console (Not web console) then try to activate the licence again, this time it should work.
    SP6 needs to be applied to all new installs of V10 of 3CX before a licence can be activated.
  5. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Please see this:
    http://www.3cx.com/blog/releases/3cx-license-activation/
