Solved License Activation Failed | license_error.HttpsError
Discussion in '3CX Phone System - General' started by n9zwy, Nov 28, 2016.
  1. n9zwy
    Nov 28, 2016
    I have just recently installed v15 on my Windows machine. Everything was great up until I was registering.
    The impassable error is "License Activation Failed license_error.HttpsError".
    No matter what I do, I cannot get past this. Looking at another similar forum topic, I did what the recommended steps were. But, they didn't help. The URL is: post184655.html?hilit=license_error.HttpsError#p184655
    Any help is most appreciated. Thank you, and blessings.
    Todd
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hi there,
    If the steps didn't work make sure that windows firewall is disabled and no antivirus is installed on the server.
    Also try an nslookup towards erp.3cx.com and make sure you can resolve it correctly.
  3. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    10
    Help, I have the same issue. the nslookup for erp.3cx.com returns 151.80.125.67. I have paused Kaspersky and windows firewallis is turned off. Any ideas?
  4. jasonhayes
    May 9, 2012
    140
    10
  5. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Glad to hear it worked :)
