Solved License Activation Failed
Discussion in '3CX Phone System - General' started by Grootma, Oct 4, 2017.
  1. Grootma
    Oct 4, 2017
    6
    I've been having troubles getting my 3CX server activated. It is installed on a Hyper-V virtual machine (Windows Server 2016), running all latest software updates.
    DNS is set to 8.8.8.8, firewall is disabled, antivirus is disabled, DPI on Fortigate firewall is disabled
    NSLOOKUP activation.3cx.com resolves to 151.80.125.88
    NSLOOKUP erp.3cx.com creates a DNS time-out, don't know if this is in use anymore.
    All services have been restarted, DNS cache has been flushed.
    I still get this message:
    "License Activation Server cannot be reached.
    Check your network and DNS settings.
    What more can I do to fix this? I would very much like to try 3CX and buy a full version eventually, but these activation troubles are annoying.
    Regards.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Grootma,
    Can you reach the erp server through CLI by command tracert to this IP address 151.80.125.67?
  3. Grootma
    Oct 4, 2017
    6
    Hi GiannosC,
    Thank you for your reply!
    TRACERT 151.80.125.67 shows this result, so I guess I can't reach it:
    Tracing route to erp.3cx.com [151.80.125.67]
    over a maximum of 30 hops:
    1 <1 ms <1 ms <1 ms 192.168.1.99
    2 8 ms 6 ms 4 ms poweredby.infra.3musk.nl [***.***.***.25]
    3 3 ms 7 ms 7 ms poweredby.infra.3musk.nl [***.***.***.1]
    4 1 ms 7 ms 7 ms poweredby.infra.3musk.nl [***.***.***.2]
    5 4 ms 7 ms 7 ms rono-it.nikhef.jointtransit.nl [213.207.15.73]
    6 9 ms 12 ms 10 ms jointtransit.nikhef.openpeering.nl [82.150.153.89]
    7 4 ms 7 ms 6 ms telecity-ixr.openpeering.nl [217.170.0.244]
    8 * * * Request timed out.
    9 * * * Request timed out.
    10 * * * Request timed out.
    11 15 ms 16 ms 16 ms po7.rbx-s7-6k.fr.eu [188.165.9.80]
    12 * * * Request timed out.
    13 * * * Request timed out.
    14 * * * Request timed out.
    15 * * * Request timed out.
    16 * * * Request timed out.
    17 * * * Request timed out.
    18 * * * Request timed out.
    19 * * * Request timed out.
    20 * * * Request timed out.
    21 * * * Request timed out.
    22 * * * Request timed out.
    23 * * * Request timed out.
    24 * * * Request timed out.
    25 * * * Request timed out.
    26 * * * Request timed out.
    27 * * * Request timed out.
    28 * * * Request timed out.
    29 * * * Request timed out.
    30 * * * Request timed out.
    Thanks in advance.
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Grootma,
    I have sent you a P.M, please check you inbox.
  5. Grootma
    Oct 4, 2017
    6
    GiannosC_3CX likes this.
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Grootma,
    Glad to hear the issue is resolved and thank you for sharing the solution :)
