License error Vad 3.0
Discussion in 'CRM / Helpdesk / App Integration' started by Michaelhal, Sep 25, 2012.
  1. Michaelhal
    Nov 18, 2011
    8
    Dear 3cx support team ,
    We recently had our VAD (NFR) license upgrade insurrence updated , but when i try to activate the license i get a error :
    License key activation failed Licence 104 System 0
    Can anyone tell me whats going wrong here ?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    That error code means that the license has been activated too many times in different PCs. Contact sales in order to check if they can fix the problem in the ERP.
    Regards,
  3. Michaelhal
    Nov 18, 2011
    8
    Sales resseted my license ty for your reply, sticking to one machine from now on !
  4. ezpc
    Jun 1, 2012
    40
    Was it really NFR?
    I asked if I could a key for a possible project and was told that they don't give VAD on NFR :(
  5. VAD_Support
    Aug 6, 2009
    690
    No, there are not NFR licenses for the VAD. If you are wondering if you can do what you need to do with the VAD, drop us a line and we'll let you know, so you're sure that you will be able to build your project before purchasing the license.
