License Exceeded, The Caller's Perspective?
Discussion in '3CX Phone System - General' started by Randall, Apr 17, 2017.
  1. Randall
    Mar 27, 2017
    30
    17
    Anyone know what callers hear when all licenses are in use? Does the line still ring? Can they get into an IVR? I've never bumped into this question before.
    Thanks!
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,557
    234
    You get a message saying 'License limit exceeded' or something to that effect. Not very professional. If you want to avoid that you can either purchased a higher limit license or set the trunk call limit lower than your license limit which should return a busy signal (depending on your provider).
  3. Randall
    Mar 27, 2017
    30
    17
  4. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    You can change the audio file for license limit for something nicer like: please try again...
    Good luck
  5. supplenta
    Oct 3, 2012
    35
    I downloaded an engaged tone file and I play that instead.
