License has expired even thought I paid?
Discussion in '3CX Phone System - General' started by JimbobNZ, Mar 6, 2017.
  1. JimbobNZ
    Dec 2, 2016
    13
    My 3CX Phone System Standard Edition license has expired even though I paid for it about two weeks ago.
    Does this mean I'll have for the product again plus maintenance?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Normally you should reactivate your license.
    For maintenance -- renewal is optional for V.14 and before, for V.15 you probably will have to, unless you are not using your own FQDN and SSL certificate.
  3. JimbobNZ
    Dec 2, 2016
    13
    I've found out that my re-seller had not processed the order.
