License Info: Load Failed - Error licence
Discussion in '3CX Phone System - General' started by bobdigby, Feb 21, 2014.
  1. bobdigby
    Feb 20, 2014
    19
    I have been happily trailing 3CX for a few months now using the demo license •Demo Key: SAOY-3LMW-U3OT-GLJV
    This allows me to use all the features but only with 2 simultaneous calls which is fine. Recently all the standard features have become greyed out and will not work.
    In the server activity log there is a message stating: License Info: Load Failed - Error licence Licence: 27 System: 2
    I also cannot activate the license again in the 3CX admin portal as it say is Unexpected error: License Key is in use already License 27 68 System 2 0
    Please can you advise on how I get it working again as I was enjoying testing out all of the standard features.
    Bob
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    the demo version is reportedly monitored and at some point 3cx will disable it. presumably, they feel that after a point the testing needs to come to an end and the expectation is to convert to a paid version or be happy with the free version. this may be your issue.
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,198
    188
    @bobdigby
    Backup, uninstall and then reinstall/restore. Should fix the issue
  4. bobdigby
    Feb 20, 2014
    19
    Thanks @cobaltit this worked well.
    Cheers
  5. MrKoen
    Jul 3, 2009
    61
    Ran into the same problem after moving the 3CX demo activated server to another Hyper-V host. Reinstalling fixed it. Thanks!
