License information
Discussion in '3CX Phone System - General' started by Albert464, Jan 12, 2019.
  1. Albert464
    Oct 21, 2017
    26
    Hi, can I have multiple free licenses associated with the same email? If I fill out the form on the site it sends me the one I already have. How should I add a free one?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,611
    209
    Unless something has changed recently then I find this odd.
    It was the case that free licences were bound to email addresses - so if you were to go back onto the 3CX website and applied for a new licence with the same email, it would simply spit out the originally bound licence.
    If you can bind multiple licences to a single email you could then in theory download limitless FREE licences now.
    Albert464 and florink like this.
  3. florink
    Feb 8, 2018
    35
    12
    That's still the case and it makes sense. In order to get a new license key you need to provide a new email address. Otherwise, as you correctly said a user would be able to get unlimited free licenses.
    Albert464 likes this.
  4. Albert464
    Oct 21, 2017
    26
    Thank you very much!
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    That is correct. You can only have one free licence per email.
