license KEY
Discussion in '3CX Phone System - General' started by asfuture, Jan 16, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have a question: i'm running 3CX now on my laptop. i want to uninstall it en install it on another PC. may i use the same license key there for or need i another key??
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Yes, its work. You do not need another key.
