License Limit is reached when automatic DND kicks in/out
Discussion in '3CX Phone System - General' started by richardwvm, Jun 20, 2017.
  1. richardwvm
    Dec 21, 2015
    27
    I get multiple warning e-mails for licence limit is reached when our extensions go in/out of DND at the start and end of each business day.
    Should 'Dial Code' calls be included in the simultaneous call count? I don't think they should.
    Regards,
    Richard.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @richardwvm
    What version PBX are you using and what type of phones? When the switch is done automatically using office hours this is done by a SIP info message from the PBX to the phones. If you are using dial codes however manually from the phones then these do count as simultaneous calls as the phones are calling the PBX.
  3. richardwvm
    Dec 21, 2015
    27
    Product 3CX Phone System Professional Edition
    Version Number
    15.5.5
    Snom 821
    Yes I noticed the behaviour changed with the advent of 3CX 15, as the phone now seems to know it's in DND out of hours (on the display), whereas it never used to.
    I have not configured anything to use dial codes, I've only configured the "Automatically switch status to available during office hours" option.
    Is it possible the SIP info message causes the phone to dial the DND dial code?
  4. YiannisH_3CX
    May 10, 2016
    4,349
    274
    I tried replicating your scenario but had no success. With that in mind i will send you a p.m. and request some files so we can check why you are facing this issue.
