License limit message
Discussion in '3CX Phone System - General' started by dichter, May 13, 2010.
  1. dichter
    Jan 4, 2010
    6
    2 or 3 times a day I have to restart my 3cx server because of a "License Limit Message"... I have only one or none active calls and same message, here is my log:
    I recently updated form version 8.0 to 8.1024 and same problem...
    I have 2 SPA-3102 as gateways and they work OK i think... and 1 PAP2T, 1 Linksys phone and 1 softphone, everything is working alright I just have this issue...
  2. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    First we need to see the whole log
    Also when you plug in a gateway to your telco's line, you have to tell the gateway what disconnect tone it should expect to receive in order to detect the disconnect tone, or the busy tone and disconnect the call.
    This information is in the Regional settings
    You can get this information from your telco.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    example my busy tone is this
    480@-19;620@-19;10(.5/.5/1+2)
    But if you are in country X and you put this, it is not going to work for you. These are country Dependant settings.
