license limit reached
Discussion in '3CX Phone System - General' started by a2om, Jun 10, 2010.
  1. a2om
    Apr 28, 2010
    6
    Hi, We keep getting "license limit reached" for no good reason. (that i can see.)
    Here is a piece of the log:
    There was 1 person on a call at the time. We have an 8 call SMB license.
    I don't know what to make of [166,241,247,451,494,526,625,636,637] after the active calls line...
    There are no calls active when that comes up.
    Any ideas or can anyone point me to more relevant information to help diagnose this issue?
    Thanks,
    Antony
  2. m.fokkert
    Sep 18, 2008
    Same problem here still no solution in all other topic about this.
    3cx v8 fully updated.
    Mark
  3. mlsoluciones
    Jun 10, 2010
    I have exactly the same problem :( , only with 2 simultanious call :(
    Active calls counted toward license limit []
    Have you solve this?
    thanks a lot
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Have you purchase a support contract so we may passs this issues trought the correct channel, also resetting the PBX will solve this for a short time.
  5. snix
    Jun 15, 2010
    we have the same problem.
    No active calls when we get this error...
    Also we know it solves the problem for a while after restarting the services.
    Is ther any solution?
    Thanks,
    Ben
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Extensions/Trunks/System extensions Status pages should show those calls and you can collect more informations about them.
    Also, you can drop calls from management console (see Disconnect call button at the top of the pages)
  7. a2om
    Apr 28, 2010
    6
    hi,
    no as of yet i have not.
    its not just me having this problem so it is unlikely to be a problem with my set up.
    should i pay a problem with the software? i dont think so!
    Basically my 3cx box registers approximately 7 calls all the time even though none are active. They do not show on the extensions as in use. I reset the service and as you say it does solve this for a certain period. If you know this it seems you also know the solution...
    Antony
  8. turnkey
    May 9, 2009
    64
    Hi Antony,
    I've got the same problem with a customer's 3CX box, calls dropping or unable to make calls and call license limit is high also.
    @mfm I've got a support ticket open (KMO-696857) - I'm waiting for a response from the tech team now.
  9. a2om
    Apr 28, 2010
    6
    turnkey, i would very much appreciate knowing any info you get back... :)
    mfm, fyi - i have no problem with buying support when it is for a problem that I have created for myself... it seems that this isnt the case here.
  10. turnkey
    May 9, 2009
    64
    No problem at all.
    Yes I agree it appears to be a bug with 3CX as many people are having the issue.
    I hope they resolve it soon as my customer is getting very frustrated.
    It seems that 3CX is unable to disconnect calls hence why the call count keeps rising, as a new call goes over the top of the previous one. - But i'm no expert.
    Let's hope 3CX get back to us as soon as possible.
  11. turnkey
    May 9, 2009
    64
    Hi Antony,
    Which version are you running?
    We are running 8.0.10824.716 - It seems there is a known bug with this.
    According to tech support by upgrading to the latest version it's okay; http://www.3cx.com/downloads/v8rep/3CXPhoneSystem8_8.0.11596.758.exe
    So backup your current system, uninstall, install updated version and then restore the DB.
    Good luck
  12. turnkey
    May 9, 2009
    64
    Unfortunately this has not resolved it for me.
    My customer is still having calls drop, waiting for my support ticket to be answered by 3CX tech support.
  13. scheidell
    Jun 18, 2010
    This appears to be a serious problem.
    We just started to investigate a replacement for our sipx server, but if calls don't hang up, and 'tick' a license limit, this seems to be a built in DOS.
    If the trunks don't hang up, then not only do you have a problem with licenses, but you could be paying for hours and hours and hours of trunk charges.
    is this with some specific trunk, type? PSTN or SIP trunks?
  14. a2om
    Apr 28, 2010
    6
    ...in our case we are using SIP trunks. I am not so sure that they dont hang up... maybe it is just that the 3CX system is not realising they HAVE hung up :?:
  15. scheidell
    Jun 18, 2010
    this is bad. we would have been using SIP trunks.
    if your sip provider has call logs, check to see how many mins it thinks you are on.
    If this is a known (and seemingly reproducible problem for many users), this would make 3cx unusable for SIP trunks.
    does it seem to matter if you initiate the call? or if it goes through the AA? or DID?
    does it happen when you make OUTBOUND call?
    does it matter if the call was transferred (blind or attended)? or who hangs up first?
    I can't imagine this happening for everyone, or as I said, 3cx would not be useful in a production environment.
  16. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    We have an installation update for this
    Please download this package which contains a fix for this problem.
    Sorry for inconvenience caused
    Let us know if you have any problems
    Thanks and regards
  17. a2om
    Apr 28, 2010
    6
    You will see on the previous page that user turnkey was told to try this and it hasn't solved it for him.
    We will try this tonight (out of hours) but further investigation may well be required.
  18. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Turnkey - Can we see logs, Can you send me the ticket it?
  19. turnkey
    May 9, 2009
    64
    Yes, this is the version I was told to try. It certainly does solve the License issue for me, however, now I'm having major ACK errors, where calls drop every 30 seconds.
    I've just posted a new topic here: http://www.3cx.com/forums/major-bug-with-ack-15685.html
  20. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Yes I checked with support - you have a networking problem.
    So there is no relation with license limit reached.
    Your problem will be dealt with in other means not in this post.
