license loading error
Discussion in '3CX Phone System - General' started by petruskeller, Oct 17, 2007.
  1. petruskeller
    Oct 17, 2007
    I have installed the 3cx phone system. I can seem to get it working. The message "license loading error" in server status. What am I doing wrong? Keller
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Is this the free version or a paid one?
    Sometimes I get that on startup but then usually fixes itself a short time later.
  3. petruskeller
    Oct 17, 2007
    Free
    Free version
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Free version does that since there is no Lic Key entered. Does not create any problems, ignore. Does not show after a Key is entered.
  5. petruskeller
    Oct 17, 2007
    Thanks, Keller
