- Joined
- Mar 10, 2009
- Messages
- 50
- Reaction score
- 0
I've had to reinstall 3CX PhoneSystem v11 on a new host (Win7), and I restored the last backup. But when I try to make incoming calls then I get a message that Call Queues are not available with free version. And in the server log I see
27-sep-2013 19:15:35.581 [CM503025]: Call(C:7): Calling T:EndCall:EndCall@[Dev:sip:[email protected]:40600;rinstance=8a01961813e41340] for L:7.1[Line:10002<<0705399857]
27-sep-2013 19:15:35.536 [CM101004]: License Limit: Call Queues are not covered under current license
27-sep-2013 19:15:35.535 [CM505003]: Provider:[NETatONCE privat] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060]
27-sep-2013 19:15:35.535 [CM503001]: Call(C:7): Incoming call from Line:10002<<0705399857 to <sip:[email protected]:5060>
27-sep-2013 19:15:35.534 Line limit check: Current # of calls for line Lc:10002(@NETatONCE privat[<sip:[email protected]:5060>]) is 1; limit is 3
27-sep-2013 19:15:35.529 [CM503012]: Inbound office hours rule (unnamed) for 10002 forwards to DN:64
And if I try to reactivate my license then I get a message that the license number doesn't seem to be a 3CX license.
What is also odd is that under Product details on Win7 Product="3CXPS" even if my license says that I have "3CXPSMINIUI" on XP
This configuration used to work fine with my old XP system (which just crashed). Does anyone have any idea what can be wrong ?
Attached screendumps showing difference when running on XP and Win7, where XP runs fine but the same configuration on Win7 doesn't work.
Regards
Regards
