License not working... v15
Discussion in '3CX Phone System - General' started by joshuao3, Apr 1, 2017.
  1. joshuao3
    Jan 11, 2013
    20
    I bought a Standard License for 8 lines. All was working well until I ran the Firewall checker. Suddenly one of my trunks shut down. When I decided to delete and re-add the offline trunk, v15 says I'm on the PBX edition instead of standard. And, some of my phones are acting CRAZY! What the heck! How do I fix this?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    ensure all services are running correctly. antivirus not actively scanning... reboot?
    what do you mean your phones are acting CRAZY?
  3. joshuao3
    Jan 11, 2013
    20
    Yes, restarted the PBX, rebooted the host machine, rebooted the phones, factory reset the phones...
    1. Phones are acting like they are having STUN traversal issues. They can't receive inbound calls.
    2. I call one extension, a different extension rings
    3. I press the offhook button and get no audio. I hang it up, then 2 minutes later it goes offhook on its own and I have to unplug it to make it stop.
    4. When I call some lines from other lines it take 15 seconds to start ringing, it'll ring once, then the caller show a 480 error. Then the next time it rings right away.
    I turned the CMlog level all the way to 6 and am using the 3CX log reader to examine the bldef file. I don't see anything in there that's useful at explaining what's going on.
    Backwards land. It all seemed to start when I ran the firewall check from the dashboard. The worst part is my license seems to be nuked and I don't know how to fix it. Am I going to be forced to reinstall?
  4. joshuao3
    Jan 11, 2013
    20
    Screenshot from Dashboard:
    Screenshot from Log:
    I have a standard license with 8 calls, yet a third simultaneous call is being rejected.
    Can anybody help me understand what it going on? This is a fresh install! And yes, I've restarted the service, rebooted the machine.
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Have you tried re-entering your licence?
  6. joshuao3
    Jan 11, 2013
    20
    I would happily do that, but I don't see how to do that. The license key field on the "License Setting" interface is grayed out. Perhaps there is another way to re-enter it?
  7. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    it's grayed out, but does it contain your licence that you paid for ?
    does the firewall checker pass ?
  8. joshuao3
    Jan 11, 2013
    20
    Yes, it does. And yes the firewall checker passed.
  9. joshuao3
    Jan 11, 2013
    20
    Is it possible that the 3cx instance could not validate the license, so it was downgraded? Would that show up in the log? If so, what should I search for?
  10. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes it could be. I'd contact your 3cx distributor to have them check that all is well, AND/OR, submit a support ticket with 3cx (like right away).
    Not sure about log entries.
  11. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Click on license and and then press edit and OK. That should force your PBX to re-activate your license. Let us know if that worked
