License problem
Discussion in 'CRM / Helpdesk / App Integration' started by Molsen6, Apr 6, 2011.
  1. Molsen6
    Mar 14, 2007
    32
    I having problem with VAD. The activation goes okay, but when starting the application, it says "Product license has not been activated, using free features only."
    Any ideas?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Are you using a VAD license? The NFR key for example does not work. Is that your scenario?
    Thanks,
  3. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    Need the Partnes buy VAD or can we use it with an special Key ?
  4. VAD_Support
    Aug 6, 2009
    690
    That is something you need to ask your channel manager to be 100% sure. My area of expertise is technical. But I think you need to purchase a license, I think there are no NFR keys for the VAD...
