License Settings info?
Discussion in '3CX Phone System - General' started by PatM, Feb 14, 2018.
  1. PatM
    Jun 7, 2017
    5
    So having a complete brain fade and for the life of me can not come up with the correct answer so here I am. When first installing 3CX software on a bare metal computer, and going through all the settings, whose information is entered into the Customer Details section? i.e. Company name, contact name and such. I know the installing dealer is linked with the Reseller ID but is that info also in the Customer info. I want to say no but seeing what everyone else's consensus is.
  2. PatM
    Jun 7, 2017
    5
    So brain finally started working and got my answer. Now the next question is. How can you actually make the change? If I go into settings and then License, Edit and then modify anything under the Customer Details it reverts back to the original settings without saving, I have tried it on Safari, Microsoft IO, Chrome in Incognito & Microsoft Edge. So what is the trick to changing those settings. I can make the change on a Professional license but a Standard license is a no go.
    Any help is appreciated.
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Kindly contact your regional sales representative in order to assist you, the contact information can be found in the below link: https://www.3cx.com/company/contact/ select your region and give them a call.
    After that you need to navigate under the Management Console >> Settings >> License >> and press the "Refresh License Key Information" and the new details will be changed also in the phone system server.
